Marco Posted July 3, 2010 Share Posted July 3, 2010 The front axle casing of my Defender needs replacing (leaking diff pan etc.), it's an 1989 model 127/110 axle. For some reason it's difficult to get a replacement part, does anybody know where to look, which company to contact? All sugestions welcome. I might also consider swapping a complete axle or just axle casing and differential. Cheers Marco Quote Link to comment Share on other sites More sharing options...
jbs Posted July 4, 2010 Share Posted July 4, 2010 you can buy replacement diff-pan's from here http://www.steve-parker.co.uk/proddetail.php?prod=SPCK210&cat=12 Or you could follow hybrid from hells own creation using I believe a Toyota diff-pan which is at least 4x thicker than the standard land rover one HTH John Quote Link to comment Share on other sites More sharing options...
Marco Posted July 6, 2010 Author Share Posted July 6, 2010 Thanks, I'm actually looking for a complete casing, do not want to weld onto this axle. It's a 1989 one and has been up and down trough Africa on a 2.5 year trip.. it's time to replace :-) I've found a complete casing at the lrseries website.. not cheap but will probably last for another 20 years! Cheers Marco Quote Link to comment Share on other sites More sharing options...
Maverik Posted July 6, 2010 Share Posted July 6, 2010 Would it not be cheaper to buy a 2nd hand front axle then strip and re-build? Something to note/check: earlier axles have narrower front rad arm mounts - also imperial bolts that hold the calipers on. Quote Link to comment Share on other sites More sharing options...
Maverik Posted July 6, 2010 Share Posted July 6, 2010 Just spotted this.... they may courier it across for you? http://cgi.ebay.co.uk/Land-rover-90-110-front-axle-case-/270602316333?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f0127aa2d Quote Link to comment Share on other sites More sharing options...
