Disco-Ron Posted July 11, 2010 Share Posted July 11, 2010 I have bought anew heater box for my 90..... but don;t wanna start ripping it apart only to find it can't be changed without removing the front wings.... so, in short, can it be done with the wings in place,...?? 300tdi..... Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 11, 2010 Share Posted July 11, 2010 The end of the heater box is just tucked under the edge of the wing. To replace the matrix you need to drill out the rivets that hold the top panel on and then bend it up far enough to remove the matrix. You can chip the rivets off with a very sharp chisel, and perhaps leave a few out, but it's very fiddly to do. Les. Quote Link to comment Share on other sites More sharing options...
Litch Posted July 11, 2010 Share Posted July 11, 2010 Yes it is an easy job to do with the wings in place, all you need to do is remove is the washer bottle and the heater inlet duct and you have all the access you need to remove it (I did this job again just a few months ago). Make sure you have the correct seals before you start otherwise you won't be able to finish the job. The old seal is bound to be hard & crispy and using a sealant instead of the correct foam-rubber seal just makes it a pig of a job to remove the heater in future. The correct seals (heater-box to bulkhead & heater-box to intake duct) shouldn't cost more than about £15 in total. Quote Link to comment Share on other sites More sharing options...
Landy'd Gentry Posted July 11, 2010 Share Posted July 11, 2010 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ As Litch says above! I've changed my heater without removin the wing. It's a bit tightin places but can be done. Buy the correct seal! (or get very cold, your choice!) HTH Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted July 11, 2010 Author Share Posted July 11, 2010 Thanks guys........... the brand new heater box i bought already has the seals stuck to it.... so thats that... Cheers. Quote Link to comment Share on other sites More sharing options...
