Phillis Posted July 25, 2010 Share Posted July 25, 2010 What spline will a 93 200tdi disco be? also what would happen if i put the rear axle on my 90 which will be a 10spline. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted July 25, 2010 Share Posted July 25, 2010 Change from 10-24 was around 94 time. I had a late 200 tdi on an L plate and that was 24 spline. I have seen L reg ones on 10 spline though so anything earlier should be 10 (but don't rule anything out at LR!). It really doesn't make much odds which axle you use since the ratio is the important thing and that will be the same. Quote Link to comment Share on other sites More sharing options...
