NicTheOrange90 Posted May 29, 2006 Share Posted May 29, 2006 It needs to have the internal door locking/unlocking tab pulleed fully upwards before the door handle works (think its the same for inside handle as well). In the glove box, previous owner left small plastic bag with 2 round springs... Is it a big job to replace these springs (assume they go somewhere on the locking tab).. I tried searching for this question, but to no avail. thanks Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted May 29, 2006 Share Posted May 29, 2006 Ive never done the job myself but it is a well known problem, the springs as i understand it go in the lock mechanism itself. Quote Link to comment Share on other sites More sharing options...
Mark Posted May 29, 2006 Share Posted May 29, 2006 Nic, Not a big job, just a bit fiddly to get the lock mechanism out. You need to toake the door card off, and release the lock from the door frame - unfourtunatly this involves moving almost everything else inside the door! Once you have the lock out, it is pretty easy to fit the new spring - I still have the instructions from when I did mine, I can scan them in if you like (you will have to wait till I'm at work tomorrow though!) As I say it's not complicated, just a bit fiddly, and you will be surprised how much of the door needs to come apart! Cheers Mark Quote Link to comment Share on other sites More sharing options...
NicTheOrange90 Posted May 29, 2006 Author Share Posted May 29, 2006 I can scan them in if you like (you will have to wait till I'm at work tomorrow though!)Cheers Mark Thanks Mark, no rush it will be one of the many jobs that I end up doing in the next few months ! Nic Quote Link to comment Share on other sites More sharing options...
