TD5 Water Pump replacement
Peterla
hi , it fairly self explanitary. just have a look at it and you be fine. list of parts and part numbers are here for you. water pump ERR7047
set of seals 3 in total. PFQ10001L
id have my new water pump and seals ready for when you take the old one off, so you can copy how all the seals go on for the new one. also take note of where each bolt goes.
its litterally a bolt on bolt off process.
if you need any more help let me know.
hope it helps
chris
