coolcat Posted August 6, 2010 Share Posted August 6, 2010 2002 Disco2 alpine head unit isnt working and can not be repaired.So how can i find a replacement or any unit which can also be used exsisting amplifier and steering controls.would any alpine work with it. Thanks Quote Link to comment Share on other sites More sharing options...
JourneyMan Posted August 8, 2010 Share Posted August 8, 2010 Hi, You don't list your vehicle type GS, ES etc. Any unit will work but if you want to keep the s/wheel controls you'll need a lead to convert the LR system to whichever make you go for. You'll also need a bridging piece as the High line Alpine is an odd shape, there only about a fiver from LR and they cover the hole left between the bottom of the console and the new unit, difficult to explain but you'll see what I mean when you pull it out. Quote Link to comment Share on other sites More sharing options...
teabag Posted August 8, 2010 Share Posted August 8, 2010 If you were happy with the old existing Alpine head unit u may find a direct replacement on Ebay or similar. Not all head units what ever make have the facility to interface with the steering remote controls those that do will reqiird a patch lead. U may also have to do a work-around to retain the existing amp. Quote Link to comment Share on other sites More sharing options...
