need4speed Posted August 6, 2010 Share Posted August 6, 2010 As im getting along (slowly) with my 110 build im almost ready to fit the tub onto the chassis. Now, the chassis i have is a TD5 one but the rear tub that i have restored is pre-TD5. Am i going to have issues bolting it up? I ask this because the TD5 chassis has a different rear crossmember arrangement... Quote Link to comment Share on other sites More sharing options...
mike1980 Posted August 9, 2010 Share Posted August 9, 2010 It shouldn't be a problem, mine went OK, there are two versions of the bracket which connects the tub to the rear x-member, I had the earlier one which bolts to the outside of the tub, I think the later one bolts to the inside, just a cosmetic difference really. You may need hex inserts for the outer bolts, there were none fitted on my chassis. Rgds Quote Link to comment Share on other sites More sharing options...
need4speed Posted August 10, 2010 Author Share Posted August 10, 2010 Thanks Mike. Oh and welcome to the nuthouse... Quote Link to comment Share on other sites More sharing options...
