mayur Posted August 15, 2010 Share Posted August 15, 2010 hi i have just repaired my 300tdi with a new head and headgasket and bolts and waterpump, i was planning to change the turbo but didnt have time to get the brackets sorted so i just my old turbo. also no egr problem is when i start the car it has a slight amount of smoke on startup but when i rev up above 1000 revs i get a smoke screen comming out the back so thick that you can see anything which annoys the neighbours abit any idea on what it can be ?? thanks Quote Link to comment Share on other sites More sharing options...
Paul 200 TDI Posted August 15, 2010 Share Posted August 15, 2010 white smoke is normaly water in the fuel system. Might be related to the head gasket change, but could be you need new filters Quote Link to comment Share on other sites More sharing options...
mayur Posted August 15, 2010 Author Share Posted August 15, 2010 i cant quite tell if it while or blue ish but it has me worried im hopeing it carp in the exhaust but not sure, im not sure if Quote Link to comment Share on other sites More sharing options...
Paul 200 TDI Posted August 15, 2010 Share Posted August 15, 2010 I think that I would be looking at the turbo/inter cooler side of things, does it drive like it should (did?) Quote Link to comment Share on other sites More sharing options...
