muddy4x4xfar Posted September 4, 2010 Share Posted September 4, 2010 hi all iv got a discovery 2 td5. there seems to be a wuring noise coming from the ace box under niethe the motor. any ideas on what it could be or what i can do. im not overly up on the ace systems so any help would be much apprieciated cheers chris Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted September 4, 2010 Share Posted September 4, 2010 Simple check is to look for lumps of grit or stones jammed between the valve block and chassis,the valve block is rubber mounted to isolate it,the stones bridge the gap and amplify the noise. Quote Link to comment Share on other sites More sharing options...
