mikeb Posted September 12, 2010 Share Posted September 12, 2010 i need some help got a 90 v8 ii took the cap off because had a misfire put it back on now have no spark!! Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted September 12, 2010 Share Posted September 12, 2010 Lost the carbon brush, pulled a HT lead or left the rotor arm off? Quote Link to comment Share on other sites More sharing options...
oakesy Posted September 12, 2010 Share Posted September 12, 2010 1. Check your leads to the HT. 2. Check the distributor cap for the flexible centre brush. 3. Check to see if the amplifier at the side has loose cables. 4. Possible outcome HT FAILURE, AMPLIFIER UNIT FAILURE, HT LEAD FAILED, CONNECTORS BROKEN. Depending on age, mine is 1988 3.5 V8, amplifier failed on the side of the distributor. Quote Link to comment Share on other sites More sharing options...
