toon69 Posted September 30, 2010 Share Posted September 30, 2010 hi i recently bought a freelander with the bmw diesel 2.0 ltr engine and its running fine but ive found the air con pump is still running even when its switched off.the garaged have sincetold me its because i leave the temp control switch on for the windscrean or screan/body.is this correct and will my mpg be higher?thx Quote Link to comment Share on other sites More sharing options...
Mr Bean Posted October 1, 2010 Share Posted October 1, 2010 That is correct. The air con will run when you point the air at the windscreen. The air con dries the air and helps to keep it mist free. The mpg will not be affected drastically IMO. Quote Link to comment Share on other sites More sharing options...
toon69 Posted October 2, 2010 Author Share Posted October 2, 2010 That is correct. The air con will run when you point the air at the windscreen. The air con dries the air and helps to keep it mist free. The mpg will not be affected drastically IMO. thanks for your help Quote Link to comment Share on other sites More sharing options...
Blippie Posted October 5, 2010 Share Posted October 5, 2010 ... IIRC this only when the engine is cold. Once it has reached operating temp, the aircon switches off. That's my recollection, but it's Bern a while since I read the manual. Blippie Quote Link to comment Share on other sites More sharing options...
