lough90 Posted October 2, 2010 Share Posted October 2, 2010 I have just had a clutch and flywheel replaced in my td5 (99) and now find that the clutch is very heavy and I can now feel all the gears when driving. I have also had both the master and slave cylinder replaced but this has not resolved the issue. Any advise would be welcomed Richard...... Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 2, 2010 Share Posted October 2, 2010 Has the stiff clutch only occurred since it was replaced? I take it you mean pedal pressure, does the clutch drag and bite immediateley you start to lift the pedal? Les. Quote Link to comment Share on other sites More sharing options...
lough90 Posted October 3, 2010 Author Share Posted October 3, 2010 Has the stiff clutch only occurred since it was replaced? I take it you mean pedal pressure, does the clutch drag and bite immediateley you start to lift the pedal? Les. Yes the clutch pedal is heavy only after the clutch was replaced. The clutch was dragging and I couldn't get the gears so the garage replaced the master cylinder and slave cylinder which has made the pedal better but still heavy and the gears are better but not like they used to be like. I have had the car for 6 years and all of a sudden thing are failing at once and I think it may be time to get a new one...... Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 3, 2010 Share Posted October 3, 2010 The only time I've come across a TD5-engined vehicle with this type of problem was when the friction plate had been fitted the wrong way round. Les. Quote Link to comment Share on other sites More sharing options...
