chrism Posted October 2, 2010 Share Posted October 2, 2010 Afternoon all, I have a disco 300tdi engine in my truck and need to know if the pulley which the viscous fan bolts onto drives anything? The water pump appears to be on the top above the pas pump. I need to know as I may need to miss that pulley out of the belt routing or make some alterations to the front end layout Thanks Chris Quote Link to comment Share on other sites More sharing options...
white90 Posted October 2, 2010 Share Posted October 2, 2010 No just a bearing, be mindful of the direction of drive as the steering pump on a tdi cannot be reversed. Quote Link to comment Share on other sites More sharing options...
chrism Posted October 2, 2010 Author Share Posted October 2, 2010 Spot on thanks, just the answer i needed. I have pulled the gubbins out of the pas pump so it doesnt do anything, I put a bit of oil in it and sealed it up as well so that should be ok. Basically im running a big hydraulic pump for steering and winches so I only need water pump and alternator! Quote Link to comment Share on other sites More sharing options...
