davek0974 Posted October 14, 2010 Share Posted October 14, 2010 Ok so i got the hose out and flooded the poor old girl, found where my water is getting in but now need to find how to stop it doing so . Wider view of the area... It drips along this seam most of it runs down the rear pillar and onto the floor but if it was there, it would also run off the plastic trim onto the load space cover. So, where is the likely target for sealant??? Anyone got any ideas of the design of the roof/body joint, if i knew how it was made it might help. It cant be getting in any lower than the gutter line as it dont run upwards so it must be in the gutter seam somehow. Whats the best culprit???? Thanks Dave Quote Link to comment Share on other sites More sharing options...
cjmt Posted October 14, 2010 Share Posted October 14, 2010 Might rust around the Alpine window be the culprit?? Charlie Quote Link to comment Share on other sites More sharing options...
davek0974 Posted October 14, 2010 Author Share Posted October 14, 2010 I've checked all the glass-rubber and ruber-steel joints, i'm satisfied that they are all dry, it seems to be coming from the roof-body joint but where do i stick my sealant???? Dave Quote Link to comment Share on other sites More sharing options...
Pinn76 Posted October 14, 2010 Share Posted October 14, 2010 Mine's leaking from the roof to body join. All the sealant there has gone rock hard and doesn't flex with the body. An idea I had was to remove the said sealer and pop in some paintable sealant. After it rains there is no water left in the gutters but after driving for a couple of minutes I stop at a junction and get a refreshing shower through the drivers window if open! looks as if its holding under the sealant and running foward. HTH Bri Quote Link to comment Share on other sites More sharing options...
