ELVIS Posted June 12, 2006 Share Posted June 12, 2006 here we go.............. got a RRC with a daihatsu td lump and a 4 spd box with intergral transfer box! heres where it gets a bit messy!! can i fit a later 4 or 5 speed box and lt230 transfer box? if the gearboxes were interchangable between the V8 block presumeably they will be interchangeable on the conversion plate ?? Quote Link to comment Share on other sites More sharing options...
SHAVED_GORILLA Posted June 13, 2006 Share Posted June 13, 2006 Yes. If the conversion ring is for a V8 then it will fit any V8 gear box. You will need other bits though if you want to mate it to an autobox ie flywheel machineing etc. SG Quote Link to comment Share on other sites More sharing options...
