cookie64 Posted October 28, 2010 Share Posted October 28, 2010 hi all, i have a disco 1 3.9 v8 i was wondering if anybody knows much about the ABS system, what components there are to it.. if anyone has any drawings diagrams thatd be a great help. thanks tom Quote Link to comment Share on other sites More sharing options...
mayur Posted October 28, 2010 Share Posted October 28, 2010 This is what comman abs systems have 4 wheel sensors , valveunit with built in pump (moter) , warning light and control unit, considering the year of the car it won't have much else Quote Link to comment Share on other sites More sharing options...
cookie64 Posted October 28, 2010 Author Share Posted October 28, 2010 thanks for the reply i was hoping there wasnt loads o confusing electricery as im looking to rob the entire system of me dads disco for the defender Quote Link to comment Share on other sites More sharing options...
nicedayforit Posted October 28, 2010 Share Posted October 28, 2010 thanks for the reply i was hoping there wasnt loads o confusing electricery as im looking to rob the entire system of me dads disco for the defender I really wouldn't bother, cause a lot of trouble as they get older and are expensive to sort out. Have a look at the cost of bits before you go ahead. Quote Link to comment Share on other sites More sharing options...
mayur Posted October 29, 2010 Share Posted October 29, 2010 hi it really depends on why you want the ABS, i done this on my golf a few years back and it was easy. but i dont know on the discovery if the ABS wiring loom is interegated into the main wiring of the car. if it is you will have a long while striping it out! and i can tell you that from experiance :S i suggest you check to see if the axels on your defender are fitted with mounting for the ABS otherwise you have to swap axels (thats just an annoying job) things you will need to do you will need to remove the pump and valve unit from the engine bay pay CLOSE ATTENTION to which pipes go where ie front left brake , front right brake, mastercylinder IN front/back (you will have to make sure the mastercylinder pipes go to the right place on the mastercylinder) if my memory serves me right the ABS ecu was placed behind the glove box remove it (thats the easy bit ) if your lucky then the wiring wont be joint to the main loom (my mate has abs on his 97 disco i will take a look if i can get a chance) , in which case all you have to do is follow it along the car and unclip it and unscrew it from the fusebox THERE WOULD BE NO NEED TO CUT ANY WIRES ABS wiring up very easy you will have 2 (possible 3) perment LIVE wires the main to normaly being 40amps each to run the pumps and keep ecu memory, 1 IGN signal wire, and 2 GND wires (and if you feel the need install the warning light wire) Good Luck Quote Link to comment Share on other sites More sharing options...
