dellboykev Posted November 22, 2010 Share Posted November 22, 2010 hi what do you think would be the best way to waterproof the ecu on a defender without moving it i was thinking about using a sealable plastic tub but does the ecu need to breath or would this be ok? anyone got any ideas or done anything else to protect the ecu from water? Quote Link to comment Share on other sites More sharing options...
Anderzander Posted November 22, 2010 Share Posted November 22, 2010 Can I ask why you don't want to move it? Quote Link to comment Share on other sites More sharing options...
dellboykev Posted November 23, 2010 Author Share Posted November 23, 2010 yea i dont want to buy an extension cable and i like it being out of the way under the seat Quote Link to comment Share on other sites More sharing options...
Anderzander Posted November 23, 2010 Share Posted November 23, 2010 I moved mine onto the bulkhead behind the middle seat with the existing loom - I just had to lengthen a couple of wires. It was a bit fiddly but OK - it would be a doddle if you have a cubby box. Quote Link to comment Share on other sites More sharing options...
Simon119 Posted November 23, 2010 Share Posted November 23, 2010 Sorry to hijack this thread, but can you remember what size hole you had to cut for the ECU multi plug rubber seal. Have been thinking about doing this for a while now but keep forgetting to measure the hole. Also did you relocate the fuse box from under the drivers seat? If so, do those cables reach or do they all need extending?? Cheers Simon Quote Link to comment Share on other sites More sharing options...
