James NZ Posted November 24, 2010 Share Posted November 24, 2010 Hiya I purchased the Rave CD when I got my '95 disco 1 to do my own servicing/repairs. The CD's not bad but I really need a parts book. I don't want to purchase a printed book because postage from the UK to New Zealand can be horrendous! Whilst reading another thread here regarding tools I followed the link and ended up at Dingocroft web site. They appear to have the CD I want, http://shop.dingocroft.co.uk/acatalog/Books_and_Publications.html I just wondered if anybody has any comments before I order? Cheers, James NZ Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted November 25, 2010 Share Posted November 25, 2010 You get a lot for your money. As your vehicle is obviously a 'keeper' you may well find the different bits and pieces interesting. The CDs are copy protected, which means you have to have the CD in the drive while using it. You can copy the CD to a 'false' CD drive on your hard drive, but this only gives you a faster response while using the CD, as you don't have to wait for the physical CD drive to spin up just to change the page. However, the security check is still present, and you still have to have the physical CD in the physical drive. Although, given your location, the CDs are good value for money, in the UK the Microcat software application would be the normal recommendation, and if you search on this site you should find threads about it, perhaps in the International Section, perhaps in the Technical Section. Running that carries it's own challenges, but has it's own rewards, in that it covers other models so that you can get an idea of what might fit your car, etc. Quote Link to comment Share on other sites More sharing options...
fozsug Posted November 25, 2010 Share Posted November 25, 2010 How about THIS I know its a book, but postage and packing is free to OZ, so should be the same for NZ HTH Tony Quote Link to comment Share on other sites More sharing options...
ches Posted November 25, 2010 Share Posted November 25, 2010 this is what you want, microcat. http://www.retroanaconda.com/landrover/2009/12/land-rover-microcat-november-2009/ Quote Link to comment Share on other sites More sharing options...
James NZ Posted November 26, 2010 Author Share Posted November 26, 2010 How about THIS I know its a book, but postage and packing is free to OZ, so should be the same for NZ HTH Tony Thanks for your reply Tony. By the time I looked at this the listing had expired and was relisted but with postage now. With our exchange rate maybe I should look at it closer. Cheers, James NZ Quote Link to comment Share on other sites More sharing options...
James NZ Posted November 26, 2010 Author Share Posted November 26, 2010 this is what you want, microcat. http://www.retroanaconda.com/landrover/2009/12/land-rover-microcat-november-2009/ Hi Ches I downloaded this and after a bit of a work around (my cd/dvd writer in the laptop died last weekend!) managed to get it installed. Had a look and found the door lock bits but couldn't find the bit I want. The drivers door unlocks but doesn't lock with the key (no alarm fitted). The bit I need is a grey circular disc bit thing. Any ideas? Cheers, James NZ Quote Link to comment Share on other sites More sharing options...
fozsug Posted November 26, 2010 Share Posted November 26, 2010 Hi Ches I downloaded this and after a bit of a work around (my cd/dvd writer in the laptop died last weekend!) managed to get it installed. Had a look and found the door lock bits but couldn't find the bit I want. The drivers door unlocks but doesn't lock with the key (no alarm fitted). The bit I need is a grey circular disc bit thing. Any ideas? Cheers, James NZ Hi James Do you meen same as the Red bit HERE but in grey? Cheers Tony Quote Link to comment Share on other sites More sharing options...
James NZ Posted November 28, 2010 Author Share Posted November 28, 2010 Hi Tony Yes, sort off! I pulled the lock apart on Saturday and took a few pictures. The bit that is broken is the lock cylinder barrel as per photo 1. I also need the part number for the grey disc as per photo two. It has the following numbers on it - RH-R30168 >PPO-GF10<1. I presume the last bit is a manufacturing code, is R30168 a valid part number? Photo three shows were it goes, the barrel had been removed at this point. Picture four shows the clips for the door trim, I need more of these. Thanks for your help so far. Cheers, James NZ Quote Link to comment Share on other sites More sharing options...
fozsug Posted November 28, 2010 Share Posted November 28, 2010 Hi James, Think that the grey part is part of the cam assembly so i think you have to buy the complete lock as per my previous post but the other side which is RTC6690 Linky The trim clips i will have to have a look tommorrow for part numbers Cheers Tony Quote Link to comment Share on other sites More sharing options...
fozsug Posted December 8, 2010 Share Posted December 8, 2010 The trim clips i will have to have a look tommorrow for part numbers Hi James Trim Clips are MWC9134 Cheers Tony Quote Link to comment Share on other sites More sharing options...
