wozzer uk Posted November 26, 2010 Share Posted November 26, 2010 Dear all Members so here goes small hissing sound from no4 piston right at the back of the engine no water in oil runs fine not even overheating its right at the back facing bulkhead going to take the head off and change the gasket is it worth while getting it skimmed as well or would this be a waste of time use landrover daily and cant afford to have it of road for long cheers warren Quote Link to comment Share on other sites More sharing options...
barmiebrumie Posted November 26, 2010 Share Posted November 26, 2010 I have had this happen twice now, once on a 200 & once on a 300 & both times just changed the headgasket without getting them skimmed without any issues. John Quote Link to comment Share on other sites More sharing options...
scube Posted November 26, 2010 Share Posted November 26, 2010 Oh most defiantly if you have to take the head off for head gasket get it skimmed You would lick yourself if you didn’t and it leaked again. Quote Link to comment Share on other sites More sharing options...
fozsug Posted November 26, 2010 Share Posted November 26, 2010 Skim it for sure Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted November 26, 2010 Share Posted November 26, 2010 This is a common failure point for headgaskets on 200tdis I believe, it happened to mine about 6 years ago. I'd look at the situation from the perspective of whether you're willing/able to repeat the job a second time, if not-skimming it the first time causes it to fail again. I had the head skimmed. Quote Link to comment Share on other sites More sharing options...
