Debs. Posted November 28, 2010 Share Posted November 28, 2010 As (seemingly) per general acceptance; when starting a diesel engine from fully-cold, I`ve always left the glowplugs to cycle and then, without touching the throttle, cranked for between 8-15 seconds (time varies depending on temp.) and she`ll fire*. Today, during a moment of shivery absent-mindedness in the -17 C. temps. we`re enduring here in the mountains, I dabbed the throttle pedal (as I used to have to do all the time when cold-cranking my old Series III) and I was surprised how much more quickly the engine fired, actually only needing 1 or 2 seconds on the starter. So, is this a sign of something a`miss, or does everybody dab the throttle of their 300 tdi when cold-cranking? *On 100% DERV with two batteries and four known-good glowplugs. Quote Link to comment Share on other sites More sharing options...
Oil Leak Posted November 28, 2010 Share Posted November 28, 2010 It was only -7.2 here this morning when I started the car. I start as per your method (I also holding the clutch peddal down). Never tried dabbing the throttle. May give it a try tomorrow. I almost thought I was going to have to give the glow plugs a second blast this morning, as it turned at first very slow, but burst into life within 5 seconds i reckon. Working glow plugs are a must! As for something a miss, i've no idea sorry.... Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted November 28, 2010 Share Posted November 28, 2010 See also thread http://forums.lr4x4.com/index.php?showtopic=62683&view=getnewpost&hl=&fromsearch=1 in the Defender forum. Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted November 29, 2010 Share Posted November 29, 2010 Yup, dabbing the throttle is sometimes good to make it catch, but don't let it rev! It has the effect of injecting a little more fuel so easier starting. By comparison, the engines I work on (13,000 hp) are started at full fuelling (i.e. foot slammed through the floor). Mind you, they are already at 80 degrees and have a pre-lub pump to get the oil around everywhere before turning the key. Quote Link to comment Share on other sites More sharing options...
nicks90 Posted November 29, 2010 Share Posted November 29, 2010 glow plugs - 300tdi - problems starting it in the cold.... i dont think i have ever turned the ignition on and waited for the glow plug light to go out on my 300tdi before starting it. ALWAYS fires within 2-3 seconds. Only time it didnt start on the button like that was when i had a ropey battery about 3 years ago and the cold killed it. Turn ignition on, foot to floor, crank. As soon as it catches take foot off pedal. Literally never more than 3 seconds cranking before it catches and straight into a lovely smooth idle. Thats with 158k miles on the clock as well. Quote Link to comment Share on other sites More sharing options...
