bushwhacker Posted November 28, 2010 Share Posted November 28, 2010 Hi. Does the axillary belt tensioner come apart or should I not go there? Done the wee bearing on the small pulley but I still have a squeal is there any other bearings I can change. The belt runs fairly tight, should it? Quote Link to comment Share on other sites More sharing options...
Adam001 Posted November 28, 2010 Share Posted November 28, 2010 I assume you are talking about a 300tdi. Quite often the pulley can be fine, it's the belt that can squeak, this happened to my friend when she changed the tensioner and belt at the same time, swapped to the old belt and the squeal went away. Quote Link to comment Share on other sites More sharing options...
maxtherotti Posted November 28, 2010 Share Posted November 28, 2010 have also heard of the tensioner wearing internally so pully runs at a slight angle causing noise Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted November 28, 2010 Author Share Posted November 28, 2010 Sorry yes the 300 tdi The tensioner pulley does run a bit of. New belt first. Can the tensioner be opened? Quote Link to comment Share on other sites More sharing options...
maxtherotti Posted November 28, 2010 Share Posted November 28, 2010 i belive once the tensioner arm starts to run off its either put a penny/washer behind it to level it up or new unit time Quote Link to comment Share on other sites More sharing options...
