DavidW Posted December 12, 2010 Share Posted December 12, 2010 Hi I'm really sorry if this has been covered elsewhere but my searching skills seem to have failed me. I need to replace both tubular outriggers on my 90 before going for an MOT at the end of the month. Does any one have a guide, advice or useful links that will help me tackle this? This will be the first time I've done anything like this so I'm a little nervous. Thanks in advance. David Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted December 12, 2010 Share Posted December 12, 2010 David, i had to do mine aswell, what i did was get the replacements, and then look at the job thoroughly, what i found was that the new ones appeared to be the right size to be placed inside the old ones through the chassis, so, i cut off the old ones at the outer edge of the chassis, then cleaned up the inside of what was left and basically hammered the new inside the old, you clearly need to keep the 'flange' bit upright..... cos you won;t twist it once its in the chassis..!! I then welded around the outside, and called it quits........ i am however now changing the chassis, i only did the outriggers as a short term job, hence i wasn't maybe as fussy as if i wanted it to last for years and years....... Hope that helps. Ron. Quote Link to comment Share on other sites More sharing options...
DavidW Posted December 12, 2010 Author Share Posted December 12, 2010 David, i had to do mine aswell, what i did was get the replacements, and then look at the job thoroughly, what i found was that the new ones appeared to be the right size to be placed inside the old ones through the chassis, so, i cut off the old ones at the outer edge of the chassis, then cleaned up the inside of what was left and basically hammered the new inside the old, you clearly need to keep the 'flange' bit upright..... cos you won;t twist it once its in the chassis..!! I then welded around the outside, and called it quits........ i am however now changing the chassis, i only did the outriggers as a short term job, hence i wasn't maybe as fussy as if i wanted it to last for years and years....... Hope that helps. Ron. Thanks Ron. I have the bits and I'm hoping as you suggest they will slide inside the existing tube. Sounds pretty straight forward I suppose. Did you have to dismantle anything or was access ok? David Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted December 12, 2010 Share Posted December 12, 2010 i did mine at the same tome as fitting rock sliders, so i had the aluminium sill trim off, but from mempry thats all apart from the fuel tank support.... on drivers side anyways, Quote Link to comment Share on other sites More sharing options...
