HighlandRover Posted December 13, 2010 Share Posted December 13, 2010 I recently stripped down my Warn 8274 winch as I felt the break was slipping slightly and wanted to check the overall condition of the winch. I found that there was not much friction material left on the disks so ordered myself a Gigglepin uprated break kit. My question is, is the friction material stuck onto the inner and outer break discs using some sort of glue/resin? Thanks Jason Quote Link to comment Share on other sites More sharing options...
KKMobile Posted December 13, 2010 Share Posted December 13, 2010 I recently stripped down my Warn 8274 winch as I felt the break was slipping slightly and wanted to check the overall condition of the winch. I found that there was not much friction material left on the disks so ordered myself a Gigglepin uprated break kit. My question is, is the friction material stuck onto the inner and outer break discs using some sort of glue/resin? Thanks Jason Didn't use any on mine when fitted the upgraded kit never had a problem. Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted December 13, 2010 Share Posted December 13, 2010 No there's no need for any glue. they create friction enough to keep everything locked up. Quote Link to comment Share on other sites More sharing options...
HighlandRover Posted December 13, 2010 Author Share Posted December 13, 2010 Cheers Guys, I didnt think any glue was used but they put up a bit of a fight when I tried to remove them. Guess that the 10 or so years of dust and mud welded them on! Quote Link to comment Share on other sites More sharing options...
