Tank Posted June 21, 2006 Share Posted June 21, 2006 As i said earlier i am, eventualy when i get round to it, putting a radio in my 2a. Can this be wired straight from the ignition feed, meaning it will turn off when the ignition turns of, or will it draw too much. They are only small 80W speekers. Thanks Quote Link to comment Share on other sites More sharing options...
minivin Posted June 21, 2006 Share Posted June 21, 2006 As i said earlier i am, eventualy when i get round to it, putting a radio in my 2a. Can this be wired straight from the ignition feed, meaning it will turn off when the ignition turns of, or will it draw too much. They are only small 80W speekers.Thanks are you talking of 2 * 80Wrms speakers? have a look in the manual for the head unit and see what the maximum input current is and this should aid you in determining whether it's feesible or not Quote Link to comment Share on other sites More sharing options...
Tank Posted June 21, 2006 Author Share Posted June 21, 2006 Yes 2x 80W speakers Quote Link to comment Share on other sites More sharing options...
minivin Posted June 21, 2006 Share Posted June 21, 2006 Not knowing what else you have on the ignition circuit, I'd recommend a switched feed from the ignition switch to switch a relay, so that the main power feed is then taken from the battery, through the relay when the ignition is on and then feeds the system, loosely speaking 15Amps~ is a bit much to add in with everything else on the ignition switch Quote Link to comment Share on other sites More sharing options...
