Michael B Posted June 24, 2006 Share Posted June 24, 2006 The right rear turn signal on my 89 works perfectly- until I apply the brakes or switch on the headlamps. Then everything EXCEPT the indicator flashes. Also, if I apply the brakes with the headlamps on, the tail light goes out when the brake light goes on! Please help. This is my first Range Rover, so I'm new to all this. Thanks! Quote Link to comment Share on other sites More sharing options...
v8bobber Posted June 24, 2006 Share Posted June 24, 2006 B)--> QUOTE(Michael B @ Jun 25 2006, 12:23 AM) <{POST_SNAPBACK}> The right rear turn signal on my 89 works perfectly- until I apply the brakes or switch on the headlamps. Then everything EXCEPT the indicator flashes. Also, if I apply the brakes with the headlamps on, the tail light goes out when the brake light goes on! Please help. This is my first Range Rover, so I'm new to all this. Thanks! There's got to be a bad earth somewhere I would have thought. Time to get the multimeter out! Dave Quote Link to comment Share on other sites More sharing options...
Michael B Posted June 25, 2006 Author Share Posted June 25, 2006 Thanks! Quote Link to comment Share on other sites More sharing options...
