Awaken Posted January 6, 2011 Share Posted January 6, 2011 Hi, Microcat says I need part WLD100730. I've tried the WLD500200 cap which supposedly superceeds that, and it comes up too small, it doesn't lock properly and fumes escape. It's a defender 110 TD5, SALLDHA87XA176*** So, what cap dya think I need, that comes up a bit bigger? Maybe land rover found a few old fuel filler necks and blew the dust off to fit one to my 99! Also, what is with vented/unvented, how dya tell which you need? And it needs to be locking Quote Link to comment Share on other sites More sharing options...
western Posted January 21, 2011 Share Posted January 21, 2011 if you cap screws on the has a key to lock it it should be the WLD500200 - click for picture if it only turns 1/2 way & has 2 prongs on the underside & a 3rd which retracts when the key is turbed you need RTC4740 Now STC4072 - click for picture AFAIK they are the only fuel caps that could be a possible fit. Quote Link to comment Share on other sites More sharing options...
