Shock Bushings.
ajh
How much tension preload should there be on the front shock bushings when the nut is all the way down? It's obviously physically limited but even with it as tight as it goes I don't see any deformation in the bushings and I can still move the top side to side slightly just by wiggling it. I suspect it's the combination of the various items being shorter than needed, I just want to confirm so I can add some spacers as needed today.
