boyt Posted January 17, 2011 Share Posted January 17, 2011 Hello I have a fault with my disco 300tdi it starts and idles fine, but when you drive along and hit about 3500 rpm the engine cuts in and out, seems to be that it isn't getting enough fuel, you can also get the same fault to occur when the vehicle is standing still, if you hold the revs flat out it will be ok for 30 secs then start to hunt up and down, Just wondering if any one else has had this problem? Fuel filter changed and lift pump Regards Andy boyt Quote Link to comment Share on other sites More sharing options...
fozsug Posted January 18, 2011 Share Posted January 18, 2011 sedimenter Quote Link to comment Share on other sites More sharing options...
PaulN Posted January 18, 2011 Share Posted January 18, 2011 Ditto - water/dirt in sedimenter or air in system after parts change? Quote Link to comment Share on other sites More sharing options...
