mikej Posted January 18, 2011 Share Posted January 18, 2011 When i have my heater on full it blows hot for a short time then blows cold on checking water level it is low so top up and every thing ok for day or so then get a repeat of hot cold no water in oil and can not fnd any leaks any were can any one help with this problem thanks mike Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 18, 2011 Share Posted January 18, 2011 Sounds like head gasket problems to me, losing water either to the outside of the engine or into a cylinder. Quote Link to comment Share on other sites More sharing options...
Puffernutter Posted January 18, 2011 Share Posted January 18, 2011 Admittedly a 300TDi Disco 1, but I'd check your carpets! My interior heater was leaking! (And I cooked the engine!) Cheers Peter Quote Link to comment Share on other sites More sharing options...
mikej Posted January 19, 2011 Author Share Posted January 19, 2011 Admittedly a 300TDi Disco 1, but I'd check your carpets! My interior heater was leaking! (And I cooked the engine!) Cheers Peter Thanks Peter i have just had new matrix fitted admittedly it had to go back 5 times as kept leaking but ok now carpets dry . thanks mike Quote Link to comment Share on other sites More sharing options...
Puffernutter Posted January 19, 2011 Share Posted January 19, 2011 That's good to know! Again, not a Land Rover, but I had a water leak in another 4x4 that I couldn't trace (no emulsifying of the oil). In the end it turned out to be a small split in a water pipe that wasn't obvious when it was ticking over and only appeared when the pipe moved (when the engine was under load). The problem was it only happened when the engine was hot and sprayed onto a hot engine where the evidence promptly evaporated! So, the point of this ramble is that I suggest give it a good run, get it good and hot, then with the engine running, give all the water pipes a good tug and yank and see what happens! Cheers Peter Quote Link to comment Share on other sites More sharing options...
