manxrover Posted January 20, 2011 Share Posted January 20, 2011 Hi all Had the problem of the fuel pipes bursting on my 2001 Discovery 2 TD5 2001, managed to get some new pipes from DLS at Matlock, but how do you remove the rear carpet, any help and advice would be welcome, Regards Brian PS. It has the two rear bins not seats (5 seater) Quote Link to comment Share on other sites More sharing options...
IanS Posted January 21, 2011 Share Posted January 21, 2011 According to RAVE you have to remove all the side trims etc, but when I did this to my Disco 1 I found I could just slide the carpet out under the trim. Took a bit of wangling to get it back. You do have to remove the little trim strip under the back door though. Quote Link to comment Share on other sites More sharing options...
M&S Posted January 21, 2011 Share Posted January 21, 2011 You will need to remove the lower rear side panels (with the buckets in) as the carpet goes right under these. That's not a big job though. I think you should be able to fold the rear seats forward and the carpet enough to get to the cover over the fuel pump. It's easy enough to do, just go carefully with the plastic trim fixings. Quote Link to comment Share on other sites More sharing options...
