stuck Posted January 20, 2011 Share Posted January 20, 2011 Hi Gent's, Wondering if you can help, I've just wired up my winch (Superwinch EPi 9.5) that I have taken of my broken RRC and put on my 110. Winch has been stood idle for a while and I noticed that when I was trying to pull off the rope (clutch disengaged)it was a bloody struggle. Now when I try to run it I can hear the brake disengaging and the motor trying to turn but the drum won't move. Before it came of the RR it had done very little work and I know I have wired it up correctly (solenoids are still on the winch, not remotely mounted) Any ideas? Thanks, Mick. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted January 20, 2011 Share Posted January 20, 2011 I would take it apart and make sure everything that should be lubricated is. I would also take a look inside the motor casing to check that it is not all furred up. Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted January 21, 2011 Share Posted January 21, 2011 On my ep9 the brake cam stick quite a lot. if you look at the gearbox end of the winch the end casing it held on with 3 small allen bolts this casing on mine siezes to the brake cam, i normally just take the casing off and emery cloth everthing down inside and put a bit of grease on it. Quote Link to comment Share on other sites More sharing options...
stuck Posted January 21, 2011 Author Share Posted January 21, 2011 Cheers Chaps. Thanks for the tip DD. Quote Link to comment Share on other sites More sharing options...
