stuck Posted February 7, 2011 Share Posted February 7, 2011 Hi all, The fuel gauge on my 110 is getting on my nerves, if you fill the tank and then go on a drive the gauge will not move from full. If you turn the ignition off and back on again it will reset its self to a correct(ish) level. I've checked all the connections etc but can't find anything wrong, I've also tried hitting the gauge to see if the needle is sticking, again no joy. Any ideas? Quote Link to comment Share on other sites More sharing options...
western Posted February 7, 2011 Share Posted February 7, 2011 could be a sticky sender unit. Quote Link to comment Share on other sites More sharing options...
Andrew Chua Posted February 8, 2011 Share Posted February 8, 2011 not that it's helping. but i have the reverse problem on mine. gggrrr... it just doesn't want to wake from empty at times, even the low fuel indicator comes on. after driving around, it would correct itself. i've checked the line and it just seems strange. Quote Link to comment Share on other sites More sharing options...
