Disco-Ron Posted February 11, 2011 Share Posted February 11, 2011 As per title, i have a 300/90, with winch, i don;t use the truck much, but when i do, i need to be able to rely on the battery to have enough guts to deal with whatever i throw at it, i don;t use it for comps as such, but general recovery work at p&p etc.... What can i do, if anything to upgrade the charging system, i have noticed recently that as its not getting much use, it seems sluggish when i start it, the battery is good, and i don;t want/need to run two batteries, or go 24v for the winch etc, it'd just be nice to get a bit more charge........... Cheers. Quote Link to comment Share on other sites More sharing options...
western Posted February 11, 2011 Share Posted February 11, 2011 you can upgrade the alternator to a 100amp unit from a Discovery 300Tdi & upgrade the associated wiring. the standard 65amp Alt & battery should be OK for occasional use. Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted February 11, 2011 Author Share Posted February 11, 2011 Cool, i'll get a disco one then, just for that bit extra oomph.......... which wires do i need to upgrade...?? Quote Link to comment Share on other sites More sharing options...
western Posted February 11, 2011 Share Posted February 11, 2011 the thick wires from the alternator to battery & stater motor solenoid. Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted February 11, 2011 Author Share Posted February 11, 2011 cheers............. Quote Link to comment Share on other sites More sharing options...
Litch Posted February 12, 2011 Share Posted February 12, 2011 The alternator itself is "Alternator (High Output) 300 Tdi 100 amp AMR5425 G". Bought myself a Denso unit just a few weeks ago and it is a straight replacement for the 65A unit, upgrade the wiring and you are away. Quote Link to comment Share on other sites More sharing options...
