kevin31031961 Posted February 22, 2011 Share Posted February 22, 2011 Hi everyone i have a Disc td5 on 03 plate , the heater when turned on sounds like a Harrier jump jet taking off ? why i have no idea, has anyone else had this problem The sound is incredible on 1 its tollerable on full you cannot here your self speak { slight exageration} but it makes the same sound as your Hoover at home blows walm air and cold but what a racket any ideas. One other problem every so often i get the hill descent traction control and abs lights come on ?? reset and everything ok for a while thanks Quote Link to comment Share on other sites More sharing options...
DiscoClax Posted February 24, 2011 Share Posted February 24, 2011 Something caught in the fins (blades) maybe. A leaf, twig, choccy wrapper, etc? Or a shot bearing allowing the fan to rub on the housing? I've had this in other cars, but not my trusty Disco Quote Link to comment Share on other sites More sharing options...
IanS Posted February 24, 2011 Share Posted February 24, 2011 Are you sure you haven't put it on screen clear which runs the fan at top speed? Or manually set the fan speed to max? They are pretty noisy when on full chat. Quote Link to comment Share on other sites More sharing options...
pegasus Posted February 24, 2011 Share Posted February 24, 2011 I have had this exact problem. Remove the card panel from under the glove box and you will see the heater motor. Remove the 3 screws and unplug the cable and the motor will come out. You will probly find leaves in there, and as the fan spins they stick to the one side and throw it off balance. While i had mine out i stripped the motor out of its case and greased the bearings, now its silent on full power. Hope this helps Mark Quote Link to comment Share on other sites More sharing options...
kevin31031961 Posted March 2, 2011 Author Share Posted March 2, 2011 I have had this exact problem. Remove the card panel from under the glove box and you will see the heater motor. Remove the 3 screws and unplug the cable and the motor will come out. You will probly find leaves in there, and as the fan spins they stick to the one side and throw it off balance. While i had mine out i stripped the motor out of its case and greased the bearings, now its silent on full power. Hope this helps Mark Hi my thanks that would seem to be the problem i'll let you know but thanks Quote Link to comment Share on other sites More sharing options...
