JAG Posted March 9, 2011 Share Posted March 9, 2011 Hi all Is it possible to put a double air intake on a 3.5 v8-each carb with its own intake-two separate air filters. Quote Link to comment Share on other sites More sharing options...
mad_pete Posted March 9, 2011 Share Posted March 9, 2011 er yes. Quote Link to comment Share on other sites More sharing options...
mad_pete Posted March 10, 2011 Share Posted March 10, 2011 Each snorkel only needs to feed half the engine. Some people run quite happily 2.5" diameter for entire of 4.6. Depends how often you drive at max revs (and therefore max air required). 2.5" inch is probably enough 4" is massive. I suppose ideally they would be the same length to be the same resistance but as long as the engine is getting air should be fine. (exhaust headers need to be the same length so cylinders expel gas into the main pipe sequentially) intakes just need air. I wouldn't make one freakish long compared to the other but shouldn't matter too much. Filters should be the same type though. Quote Link to comment Share on other sites More sharing options...
JAG Posted March 11, 2011 Author Share Posted March 11, 2011 Thx Mad-Pete Quote Link to comment Share on other sites More sharing options...
