sargejnr Posted March 25, 2011 Share Posted March 25, 2011 I have picked up a low grumbling noise when driving my disco, happens when driving straight or turning left, noise stops when turning to the right, sounds like it's coming from front passenger wheel, any help very much appreciated Quote Link to comment Share on other sites More sharing options...
DefcoL Posted March 25, 2011 Share Posted March 25, 2011 I have picked up a low grumbling noise when driving my disco, happens when driving straight or turning left, noise stops when turning to the right, sounds like it's coming from front passenger wheel, any help very much appreciated Wheel bearing does this, the noise goes when turning due to reducing the play(on the rolling surface). Sometimes you can cure the noise by adjusting the hub nut to give the correct amount of play for the wheel bearing, however when they start to rumble it is best to replace them. In addition it is best to replace both bearings (inner and outer) on both sides of truck as they would have most likely done the same work Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted March 26, 2011 Share Posted March 26, 2011 It frequently happens when the bearing is collapsing, the rumbling is cuased because the surface has gone. It happens when the grease has washed out. Quote Link to comment Share on other sites More sharing options...
