gaz489 Posted April 4, 2011 Share Posted April 4, 2011 ok so for some of you this might be a silly question...... but i have the cut off switch all wired to cut the battery and i have the positive through to earth wired on the spade connectors underneath.... but where abouts do i wire the other 2 to on a 300tdi?? where on the ignition and wheres the last wire go to exactly? help will be muchly appreciated :-) Quote Link to comment Share on other sites More sharing options...
Mocha Bear Posted April 4, 2011 Share Posted April 4, 2011 I take it that you are using one of the FIA swtiches? if so i have cut into the stop solenoid wire with the normally open spade connections so that the stop solenoid dies when you kill the switch. Mocha Quote Link to comment Share on other sites More sharing options...
gaz489 Posted April 4, 2011 Author Share Posted April 4, 2011 yeah thats what im using... thanks Quote Link to comment Share on other sites More sharing options...
