barmiebrumie Posted April 19, 2011 Share Posted April 19, 2011 Hello all long story so I'll cut it short, after a front prop snapping at 60mph & flattening the dip sick tube to the side of the bellhousing I had to take it off as I couldn't get the stick out to check the level, anyhow last night I cut the flat section out & welded a new piece in, had to weld the stick back toegther as well as I had cut through that as well . problem I have is I drained the sump & only got 5 ltrs out, re-filled with the same & its measuring above the two little hole marks, does anyone know how much fluid would be left in the torque converter ? Thanks in advance John Quote Link to comment Share on other sites More sharing options...
zim Posted April 19, 2011 Share Posted April 19, 2011 5 litres is about right on a change. you do know when checking the level the engine must be idling ? G Quote Link to comment Share on other sites More sharing options...
barmiebrumie Posted April 19, 2011 Author Share Posted April 19, 2011 5 litres is about right on a change. you do know when checking the level the engine must be idling ? G yes done that & in park while cold, just confused with the reading on the stick John Quote Link to comment Share on other sites More sharing options...
zim Posted April 19, 2011 Share Posted April 19, 2011 Been through all the gears before going into park and checking the level ? G Quote Link to comment Share on other sites More sharing options...
barmiebrumie Posted April 19, 2011 Author Share Posted April 19, 2011 Been through all the gears before going into park and checking the level ? G yes done all that as well John Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted April 20, 2011 Share Posted April 20, 2011 I'd be looking for a second hand filler and dipstick, the angle it goes into the sump makes a difference. Mine was a bit bent and it made nearly a litre difference depending on which way I put it in. Quote Link to comment Share on other sites More sharing options...
