V8david Posted May 3, 2011 Share Posted May 3, 2011 Hi all. Got the block out and on the stand (3.5 V8), and stripped apart from the dipstick tube. Now i'm being a bit of a dipstick but I assume the dipstick tube can be removed, question is how? Just checking as I don't want to break anything... Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted May 3, 2011 Share Posted May 3, 2011 It should be secured by a tag that is screwed to the block, with that out you should be ale to twist and remove the tube. Quote Link to comment Share on other sites More sharing options...
V8david Posted May 4, 2011 Author Share Posted May 4, 2011 Thank you, that sounds simple enough! Quote Link to comment Share on other sites More sharing options...
