Range Rover Sport Tow Hitch
zim
Evening,
I was wondering if anybody could advise me please.
On a range rover sport removeable tow hitch. Does the pin which retracts when you turn the little handle, come all the way back in - or does it stay out a little ?
My boss was trying to fit his, and it doesn't want to slide in. But the pin was staying out a tiny bit.
If it is supposed to be flush, is there any adjustment possible ?
This is a picture from google, showing the pin out :
Cheers
Gordon
I can't speak for the RR Sport detachable, but I have a Witter detachable towbar on our Suzuki GV. It is possible for the pin and handle to get out of sync and as a result the bar won't go in. Try pulling the handle all the way back till it clicks so the pin is retracted. In theory you should be able to insert it easily and press the release button.
It might be worth check for any grit in it too. If in doubt though it would be worth popping into your local towbar specialist or LR Dealer as what you are describing is not usual - but probably simply fixed by someone with the right "nack"!!
Martin Medforth
