willfromsussex Posted May 13, 2011 Share Posted May 13, 2011 72 Rangie, how does the interior mirror come off? ta Quote Link to comment Share on other sites More sharing options...
smokey_joe Posted May 13, 2011 Share Posted May 13, 2011 It should be spring loaded, there is a base plate screwed to the roof with the mirror clipped into it covering the screw heads. To remove a sharp yank on the mirror will usually pull it off, though this is dependant on the securing srews holding in the roof. Alternatively insert a screw driver in the joint between the base plate and the bottom of the mirror arm and lever apart. Quote Link to comment Share on other sites More sharing options...
willfromsussex Posted May 13, 2011 Author Share Posted May 13, 2011 Brill ta. It was quite tight because the pins had corroded a bit but it came out in the end. Quote Link to comment Share on other sites More sharing options...
Fett Posted June 1, 2011 Share Posted June 1, 2011 Took me quite a while to figure that out too, I was scared of breaking it lol Quote Link to comment Share on other sites More sharing options...
