white90 Posted August 31, 2005 Share Posted August 31, 2005 anyone know how to stop it going into what appears to be screensaver when I'm driving using TT or MM after afew minutes it shows the time and calender with pics from its memory I can't find anything obvious to turn this feature off Quote Link to comment Share on other sites More sharing options...
dottythe90 Posted August 31, 2005 Share Posted August 31, 2005 Its ages since I set mine, but try looking at the Settings, Today, Items tab. Check the Display Today screen if device not used time value ? Quote Link to comment Share on other sites More sharing options...
white90 Posted August 31, 2005 Author Share Posted August 31, 2005 nothing in there plus if you change your home location in tom tom how do you make it remember the change? everytime I turn it back on it goes back to the previous one set Quote Link to comment Share on other sites More sharing options...
dottythe90 Posted August 31, 2005 Share Posted August 31, 2005 Only other thing I can think of is under Settings, Password - there's an option 'Prompt if Device Unused for' x minutes. My PDA runs version 4.20 of PocketPC. Quote Link to comment Share on other sites More sharing options...
white90 Posted August 31, 2005 Author Share Posted August 31, 2005 Found via google: Is it possible to turn off the screen saver. When my Ipaq is plugged in in the car after 5-6 min the screen saver comes on. Its not cming on when I use battery power. Please help me how to turn the screen saver off. (The screen saver is the calendar with some pictures) Thank you, Ed. Hi desry71. Go to Start/Programs/Dockware. While the "screensaver" is running, tap and hold on the screen with your stylus until a menu appears. You can change the configuration there Quote Link to comment Share on other sites More sharing options...
dottythe90 Posted September 1, 2005 Share Posted September 1, 2005 That dockware option isn't on mine - I'd guess it must be an Ipaq specific utility Quote Link to comment Share on other sites More sharing options...
