seth's dad Posted May 18, 2011 Share Posted May 18, 2011 evening all, when swapping over to a disco transfer box, do you use the disco handrake cable and bracket as well, cause looking at them they seem to be different, thanks in advance Quote Link to comment Share on other sites More sharing options...
western Posted May 18, 2011 Share Posted May 18, 2011 not sure about the bracket on the transfer box, but you can certainly fit the Discovery [or RRC] handbrake as shown here Quote Link to comment Share on other sites More sharing options...
smokey_joe Posted May 19, 2011 Share Posted May 19, 2011 I have always changed the handbrake bracket over, this requires the rear output housing swapping over as the defender bracket bolts through the rear face which is drilled and tapped, I don`t think you can drill and tap the discovery one to suite because the holes would coincide with the threaded holes already there coming from the side that the discovery bracket uses. When I have looked at the possibility of using the discovery bracket in a defender it looks like the front of the seat box will block the cable but I have never offered one up to confirm this. I believe this does not relate to 300 tdis and later where the cable comes out of the back of the drum with no bracketry on the transfer box. Quote Link to comment Share on other sites More sharing options...
