V8 Freak Posted May 30, 2011 Share Posted May 30, 2011 I'd like to ask the learned people of this forum for some advice / start points to look for..... Since fitting MS I've had a very happy truck, starting first time on the key every time.... Until yesterday... Nothing changed for months, except the weather maybe.... Yesterday I popped to a local car dealer to look for a car for my daughter. The Truck was mostly up to temp, probably 70 - 80 degrees. I stopped there for maybe 5 minutes having a quick look at the cars and when I tried starting the truck... It span, and span and didn't fire into life... I could smell unburnt fuel and it was all reminicent of a flooded carb situation I used to suffer in cars 20 - 30 years ago.... A similar situation happened earlier this morning and then once again this afternoon, but the third time the truck was at full operating temperature and only switched off for a few minutes at best. The system won't permit me to attach an .MSQ file or .Zip file so PM me if you would like me to send the current MSQ file for a look over it.... Where would you recommend I look first ?? Neil Quote Link to comment Share on other sites More sharing options...
bobtail84 Posted May 30, 2011 Share Posted May 30, 2011 Neil, did you get the Msq from NIge? Have a look at the" Coolant corrected air density" in advanced setting and you need to see this... HTH Jeff Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted May 30, 2011 Author Share Posted May 30, 2011 Hi Jeff, The original MSQ file came from the reprobate we know and love as HFH the body destroyer.... Originally written for a 3.9, I amended the timing map to be less aggressive after quite a lot of reading engine on the needs of the 4.6. Most main settings remained unchanged and then run through Tunerstudio for several hundred miles... It runs real sweet. Neil Quote Link to comment Share on other sites More sharing options...
bobtail84 Posted May 30, 2011 Share Posted May 30, 2011 Hi Neil, have you plugged the lap top in and look to see if you have RPM cranking signal? Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted May 30, 2011 Author Share Posted May 30, 2011 I tried Jeff, but when I plugged into laptop to try and log etc., it started first time every time! (Just my luck...) Neil Quote Link to comment Share on other sites More sharing options...
