Bobs Posted August 7, 2011 Share Posted August 7, 2011 Hi Could anyone tell me where to find a lay-man's guide to the drive train on the freelander 2? I understand that there is no VCU, as on the freelander 1 and that as a result the vehicle is in permanent 4wd. I thought that the VCU also overcame the problems caused by the rear wheels not travelling at the same speed as the front ones when cornering ie trye scrubbing and judder. How does the FL2 overcome these problems? Is there still a IRD unit on the gear box? This is the sort of information I would normally get from the good old Haynes manuals, but to the best of my knowledge one is not available for the FL2. If anyone can suggest suitable reading, or offer information I should be most gratefull. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 7, 2011 Share Posted August 7, 2011 I believe the FL2 has a Haldex clutch instead of the VCU so it's actually permanent 4x2, only engaging the rear when needed. As such there should still be an IRD or equivalent to provide drive to the rear. Quote Link to comment Share on other sites More sharing options...
