mikej Posted September 3, 2011 Share Posted September 3, 2011 Hi i have a 2001 disco 2 a month ago i tried to use aux lamps on night run but not working checked fuses and bulbs . changed relay in engine compartment (R7)still not working also changed swith on dash no joy so ran live to bulb ok .called in at Landrover GL they checked all of same but could not give me clue to problem has any one idea how to fix problem begining to bug me know thanks mike Quote Link to comment Share on other sites More sharing options...
K88 MUD Posted September 4, 2011 Share Posted September 4, 2011 Has the option been turn on in the ICU ? (ecu) Quote Link to comment Share on other sites More sharing options...
PaulMc Posted September 6, 2011 Share Posted September 6, 2011 Hi i have a 2001 disco 2 a month ago i tried to use aux lamps on night run but not working checked fuses and bulbs . changed relay in engine compartment (R7)still not working also changed swith on dash no joy so ran live to bulb ok .called in at Landrover GL they checked all of same but could not give me clue to problem has any one idea how to fix problem begining to bug me know thanks mike R7 in the engine compartment fuse box has nothing to do with Auxiliary Lights, it's the 'Auxiliary Circuits' relay, which controls power to ignition switched circuits. Do you have Genuine Land Rover Auxiliary Lights fitted? If so, you may have the troublesome control unit VUB501690 fitted, callout #3 in this diagram - VUB501690 is expensive to replace - http://www.brit-car.co.uk/product.php?xProd=134448 Unfortunately, replacing VUB501690 gives no guarantee of a trouble-free future A cheaper, easier and longer lasting option is to replace the control unit with a relay. See this write-up on how to do it, from Urban Panzer's website - http://www.discovery2.co.uk/spots.html . Quote Link to comment Share on other sites More sharing options...
