justustwo Posted September 12, 2011 Share Posted September 12, 2011 Hi all Just as the title says ,please can anyone tell me the outside diameter size of a standard(original) spring eye bush in a series 3 Landrover.will update on why in next few days.Thanks Quote Link to comment Share on other sites More sharing options...
ejparrott Posted September 12, 2011 Share Posted September 12, 2011 How accurate do you want? Micrometer, very-near or rule? Quote Link to comment Share on other sites More sharing options...
justustwo Posted September 12, 2011 Author Share Posted September 12, 2011 How accurate do you want? Micrometer, very-near or rule? thanks for the response,just norml ruler within 1mm should be -I am expecting around 32mm??? thanks Quote Link to comment Share on other sites More sharing options...
ejparrott Posted September 13, 2011 Share Posted September 13, 2011 will let you know when i get home Quote Link to comment Share on other sites More sharing options...
ejparrott Posted September 14, 2011 Share Posted September 14, 2011 my follower for the press tool is a smidge over 30mm, thats the spring bush. IIRC chassis bushes are the same. Quote Link to comment Share on other sites More sharing options...
SeriesEwan Posted September 14, 2011 Share Posted September 14, 2011 rear chassis ones are the same, fronts are different units but not sure about their diameter Quote Link to comment Share on other sites More sharing options...
RobotMan Posted September 14, 2011 Share Posted September 14, 2011 SIII I believe are all the same diameter spring and chassis but are either chassis rail wide or spring eye/rear hanger wide. Some I & II where narrower diameter but couldn't say which. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted September 14, 2011 Share Posted September 14, 2011 Wouldnt that require bent shackles if the bushes were different widths? Chassis bush are same length front and rear, and front and rear springs re the same width Quote Link to comment Share on other sites More sharing options...
SeriesEwan Posted September 14, 2011 Share Posted September 14, 2011 no the front shackles have a distance piece in them to compensate for the gap Quote Link to comment Share on other sites More sharing options...
RobotMan Posted September 16, 2011 Share Posted September 16, 2011 Military front spring shackle as fitted to my Landy on Monday. Not very clear but they are stepped in at the spring end. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted September 16, 2011 Share Posted September 16, 2011 I've just had one of those penny dropping moments....I've been having brain-fail....the rear spring hangers are welded under the chassis rails and are narrower...the front are not...this I know because I wanted 88" rear spring hangers welding onto the 109 chassis as recovery mount points before it was galvanised...which they forgot but hey. So yes..now that brain is working...front bush is different!....If I remember, I'll have a measure of the 109's front chassis buch when I go in the garage in the morning, see if tis different. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted September 24, 2011 Share Posted September 24, 2011 Was it the size you wanted? you're keeping us all in suspense!! Quote Link to comment Share on other sites More sharing options...
