wadders Posted September 17, 2011 Share Posted September 17, 2011 Challenge Defender 90 Stolen from Barnsley Please check it out on ebay for pics etc. http://www.ebay.co.uk/itm/190572710716?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1586.l2649 • 1986 Ex-mod 90 truck cab, 35,000mls • 200Tdi engine, 1.67 ratio transfer box • LPG gas system fitted • KAM air locking 4 pin diffs front and rear with heavy duty 24 spline half shafts and drive flanges as follows: 2 x xnew HD half shafts in rear 2 x new Aero space grade half shafts in front as of 1/9/10 • AEU2522 CV’s • QT heavy duty drag link and track rod • QT diff protectors front and rear • Front mounted Warn 8274-50 with 250A isolator switch, 125ft of 11mm plasma 12 strand and stainless steel hawse fairlead New motor fitted August 2010 • D44 (Devon 4x4) front winch bumper with aluminium radiator guard around winch drum • Off Road Armoury ground anchor and D44 front bumper mount • Rear mounted Super winch Husky with 250A isolator switch 125 foot winch tape (Samson) with Cum Up aluminium hawse fairlead. • Battery isolator switch with engine cut-out • Dash mounted remote winch control switches • External winch control switches front and rear • 8x16 Mach 5 wheels • 35/10.5 R.16 SIMEX Extreme Trekkers x5 • OME (Old Man Emu)764 front springs • OME N115 front shocks Gwyn Lewis Challenge spec front turrets/securing rings (-1inch) • OME 762 rear springs • OME N44 rear shocks Gwyn Lewis rear shock drop plate / challenge relocators and spring retainers • OME steering damper • Snorkel with K&N filter • QT Services Full 6 point chassis mounted FIA/MSA/ARC/AWDC approved 48.3mm, 10 gauge CDS roll cage around truck cab. • D44 Waffles and bookends mounted on rear • Hi lift jack mounted horizontally across rear • Corberau seats • UK Covers seat covers • Cubby box • Pioneer stereo and speakers • Midland 38 CB • Rear facing Hella work light • Raised breathers for injection pump, timing case, axles and gearbox • Gwyn Lewis rock sliders with kickers • Gwyn Lewis tank guard • La-Salle door trims and removable door tops • Spare wheel mounted in load bed • MOD bonnet clasps • Towing eyes on rear cross member • Gwyn Lewis stainless steel side exit exhaust Starter motor serviced Aug 2010 with fully serviced recon unit as spare Bonnet and wings in black chequer plate 2 x Remote winch trailing leads Full set of winch straps, shackles etc Bearmach steering bar / sump guard MOMO sports steering wheel Detachable tow hitch Fire extinguisher (2litre foam) mounted in cab Life hammer mounted in cab First aid kit Chassis is wax oiled with no rust Cab internals recently hammerited no rust Oil dropped …… Respray 1/9/10 Grenville Waddington 07920502167 Quote Link to comment Share on other sites More sharing options...
Frax Posted September 18, 2011 Share Posted September 18, 2011 Not another one - its time the police made an example of these thieving gits. Frax Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted September 18, 2011 Share Posted September 18, 2011 This is my neck of the woods. Doing a bit of driving around today so will keep my eyes open. Any details on how they got it ? Quote Link to comment Share on other sites More sharing options...
brighouse shed Posted September 18, 2011 Share Posted September 18, 2011 will be working in wakefield barnsley area tomorrow will keep an eye out hopefully one of the industrial units i go past may have it Quote Link to comment Share on other sites More sharing options...
