Challenge Defender 90 Stolen from Barnsley
wadders
Please check it out on ebay for pics etc.
http://www.ebay.co.uk/itm/190572710716?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1586.l2649
• 1986 Ex-mod 90 truck cab, 35,000mls
• 200Tdi engine, 1.67 ratio transfer box
• LPG gas system fitted
• KAM air locking 4 pin diffs front and rear with heavy duty 24 spline half shafts and drive flanges as follows:
2 x xnew HD half shafts in rear
2 x new Aero space grade half shafts in front as of 1/9/10
• AEU2522 CV’s
• QT heavy duty drag link and track rod
• QT diff protectors front and rear
• Front mounted Warn 8274-50 with 250A isolator switch, 125ft of 11mm plasma 12 strand and stainless steel hawse fairlead
New motor fitted August 2010
• D44 (Devon 4x4) front winch bumper with aluminium radiator guard around winch drum
• Off Road Armoury ground anchor and D44 front bumper mount
• Rear mounted Super winch Husky with 250A isolator switch
125 foot winch tape (Samson) with Cum Up aluminium hawse fairlead.
• Battery isolator switch with engine cut-out
• Dash mounted remote winch control switches
• External winch control switches front and rear
• 8x16 Mach 5 wheels
• 35/10.5 R.16 SIMEX Extreme Trekkers x5
• OME (Old Man Emu)764 front springs
• OME N115 front shocks
Gwyn Lewis Challenge spec front turrets/securing rings (-1inch)
• OME 762 rear springs
• OME N44 rear shocks
Gwyn Lewis rear shock drop plate / challenge relocators and spring retainers
• OME steering damper
• Snorkel with K&N filter
• QT Services Full 6 point chassis mounted FIA/MSA/ARC/AWDC approved 48.3mm, 10 gauge CDS roll cage around truck cab.
• D44 Waffles and bookends mounted on rear
• Hi lift jack mounted horizontally across rear
• Corberau seats
• UK Covers seat covers
• Cubby box
• Pioneer stereo and speakers
• Midland 38 CB
• Rear facing Hella work light
• Raised breathers for injection pump, timing case, axles and gearbox
• Gwyn Lewis rock sliders with kickers
• Gwyn Lewis tank guard
• La-Salle door trims and removable door tops
• Spare wheel mounted in load bed
• MOD bonnet clasps
• Towing eyes on rear cross member
• Gwyn Lewis stainless steel side exit exhaust
Starter motor serviced Aug 2010 with fully serviced recon unit as spare
Bonnet and wings in black chequer plate
2 x Remote winch trailing leads
Full set of winch straps, shackles etc
Bearmach steering bar / sump guard
MOMO sports steering wheel
Detachable tow hitch
Fire extinguisher (2litre foam) mounted in cab
Life hammer mounted in cab
First aid kit
Chassis is wax oiled with no rust
Cab internals recently hammerited no rust
Oil dropped ……
Respray 1/9/10
Grenville Waddington
07920502167
