Ben_J85JTY Posted October 16, 2011 Share Posted October 16, 2011 Hi All, Being a bit frosty this morning I switched on my heated windscreen on the 110, which in itself wasn't anything new. After about 2/3 mins however, I could smell melting plastic, and found that the connections on either side have started to melt. Any idea's as to why this may have started happening? Cheers Ben Quote Link to comment Share on other sites More sharing options...
Guest Posted October 16, 2011 Share Posted October 16, 2011 Hi All, Being a bit frosty this morning I switched on my heated windscreen on the 110, which in itself wasn't anything new. After about 2/3 mins however, I could smell melting plastic, and found that the connections on either side have started to melt. Any idea's as to why this may have started happening? Cheers Ben Ben it's possible that over the summer the contacts have become corroded/oxidised when the juice was applied created more resistance in that area, than the connection could cope with, may just be a case of unplugging them and giving them a rub over with some wet and dry hopefully the connectors have not broken down too much. Jason. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 16, 2011 Share Posted October 16, 2011 If corroded, a squirt of eletrical contact cleaner and a wiggle could be all it needs, and the contact cleaner should help protect the connection for the future. Any motor factor should have this in stock. Quote Link to comment Share on other sites More sharing options...
Ben_J85JTY Posted October 16, 2011 Author Share Posted October 16, 2011 Cheers, I have a tin of contact cleaner in the garage (Injector loom to ECU plug cleaning!) So I'll give it a go and report back. Ben Quote Link to comment Share on other sites More sharing options...
